Results 1 to 10 of 24
Thread: Argh Double Cardan Unis
    South Yundreup,WA.
    Next time I mention I am going to do the unis and ball on the double cardan, remind me to get someone else to do it.
    I have never had so much drama fitting.
    The front uni and the front of the cardan were not to bad, even removing the ball was easy.
    Getting the ball back on the shaft far enough to allow the unis to line up was a drama and ended up having to use a press to get the seal over the last lip. Now articulation of the cardan is really tight, though should loosen with a bit of effort. Certainly not like the easy push on in the videos. Then putting in the last uni pressed a bit hard and cracked a uni cap, so off to get another uni in the morning. That last uni fitting is just a pig as has to be mm perfect,
    Way too much effort for what should be a simple job, never had so many issues with uni's ever.
    Remind me next tine to get someone else to do it.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Dec 2008
    Ha ha, I was just thinking exactly the same thing!!
    Only difference, after struggling for some time, and punching out the bottom of a cup (dropped needle) going to get a replacement, re-positioning all the centre bearing needles (again...) and getting it together, discovered that the last cup was completely loose in trunnion...... Needless to say, the spare one in the bin was flogged out even worse.....
    New shaft inbound, never touching that double cardan ever again, under any circumstances!!! Gumnut.
    South Yundreup,WA.
    Me neither, I would say very poor design, should not be that hard. Have done unis before but never this hard. Should really be a 4hr job, has turned into about 8hrs plus. Cant believe how stiff it becomes when the ball is in place. Certainly just does not push on like they show. Never again.
    Craig
    Quote Originally Posted by Gumnut View Post
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by CraigE View Post
    Usually if the cap gets cracked is because one of the needle rollers has been dislodge and fallen and is resting on the bottom of the cap.Then when pressing the cap down it had no more clearance and hits the dislodged pin causing the cap top crack. Needle rollers are held in by grease and don't like to be disturbed much. Big Cable ties also help when reassembling the double joint , like an extra pair of hand to hold things.
    Mario
    Nov 2014
    Nirvana near Albany W.A.
    ^^^x2
    It shouldn't be tight at all , as Mario said , you've dropped a needle roller, I wouldn't fit it if it was tight , and if the ball is tight on its own there is probably a dropped roller in that as well
    Cable ties are your friend, or even better a friend is your friend
    Don't forget to centralise it all when assembled
    Or give it to someone else that does them on a regular basis to do
    South Yundreup,WA.
    Quote Originally Posted by discorevy View Post
    ^^^x2
    No dropped roller on the ball, pulled off twice to make sure before pressing the last little bit, just very tight fit, much tighter than I would have thought. Only tightened up when we pressed the last 1cm on, would not push all the way home by hand that is for sure.
    Will grease up the uni properly and check for rotation.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    South Yundreup,WA.
    Now greased unis fully moves a lot better.
    ^^^x2
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Jul 2010
    Hunter Valley NSW
    The centre bearing housing has a tiny hole drilled thru to the back to relieve grease as its pressurised during assembly as the spigot is pushed into bearing. If this hole was blocked it would make assembly difficult.
    Worth a look
    South Yundreup,WA.
    Well tailshaft is done and painted, will go back in in the morning.
    Had some advice from the Hardie Spicer guys that have done these.
    1: Do not fill with grease before fitting unis, just a smear over needles to hold them in place as excess grease can cause needles to move and even damage including damaged caps.
    2: Unis and ball will be tight initially, tap with hammer to seat correctly and then grease, rotate in a vice to lubricate and free up.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    South Yundreup,WA.
    Well tailshaft back in and no dramas so a win.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
