                                                13th September 2016, 01:47 PM
			Auto window up - not working (D4)
					Does anyone know a fix for this?  I recently had electronic braking system installed and when the disco came back the Drivers side window up would not auto up.   It will auto down and all other window auto up and down.
 NB - battery was removed during installation.  I have taken it back to the 'big name' accessories store who fitted it and they can't fix it.  Suggested I take it to LandRover (WTF??).
 Has anyone else experienced this and know a fix?
                                                13th September 2016, 01:50 PM
					Manually (by holding the switch) fully open the window, and then fully close it two or three times - it should reset. You need to do this (usually with all four windows) any time the battery has been disconnected.
 Cheers .........
BMKAL
                                                13th September 2016, 02:13 PM
					You need to put the window all the way up then hold the button up for a few secs. You will hear a click and then it will work normally again.
                                                13th September 2016, 04:03 PM
                                                #4
					Both close. But not quite.
 Lower window all the way...
 Raise fully by holding button
 Once fully raised, release and then hold the button again until you hear the click.
                                                13th September 2016, 05:32 PM
                                                #5
					Thanks guys.  The up and down 3 times with 3 second hold worked.
                                                13th September 2016, 05:36 PM
                                                #6
					Pity about "the big name guys" Seems as though they really do not give a "rats a" about their customers
 Similar experience with them when I had a bullbar fitted
 No one knew what was really required to be done
                                                13th September 2016, 07:13 PM
                                                #7
					That happened with my new D4, usually happens when the window gets 'stuck' and needs a reset.  It's in the manual how to reset the Windows. It's a good idea to read that sometimes
Dave.
Hi.
96 Disco 1 V8.
99 Disco 2 TD5.
LROCV.
