Results 1 to 8 of 8
Thread: Spot light staying on after high beams turned off
    Jan 2009
    Hey Guys,
    2012 Puma and I noticed the other night my spotlights were staying on after the high beams were turned off. To turn off the spotties I'd have to hit the toggle isolation switch for them.
    Where do you guys suggest I start looking.
    Cheers in advance,
    Mick
    Bearman's Avatar
    Hay Point
    I would be looking for a relay on the power cable. Sounds like a sticking relay to me.
    Cheers......Brian
    1985 110 V8 County
    Adelaide - Torrens Park
    I am with Bearman. I have had this issue quite a few times when using relays of questionable quality (Narva).
    Jan 2009
    Quote Originally Posted by BigJon View Post
    So Jon what brand have you had luck with
    Hella.
    Kingston, Tassie, OZ.
    Poor relay earthing is also a culprit.
    Terminal 85 or 86 ( can be either) has to be earthed properly.
    Jc
    JDNSW's Avatar
    Like the others, sticking relay.
    Jan 2015
    What rating is the relay? If it is too small, it will degrade, possibly causing this fault, amongst others.
