Results 1 to 10 of 31
Thread: 6x6 V8
    6x6 Guest
    6x6 V8
    Hello everyone,
    I have a Perentie 6x6 normal set up for the moment.
    I would like to drop a V8 diesel in it.
    Any suggestions , advices , what engine/gear boxes suits best ?
    Has anyone ever done one or have one ?
    Anyone would know a company or workshop that can be trusted to do this /
    Thanks in advance.
    6x6
    Bearman's Avatar
    Hay Point
    Quote Originally Posted by 6x6 View Post
    Hello everyone,
    Thanks in advance.
    6x6
    G'day 6x6 and welcome, what brand of V8 diesel are you looking at. If it's a Chev I would forget about it. I have seen a couple of conversions with the 6.5 motor and neither was a success. Not much extra power and overheating problems. I have thought long and hard over this subject and have decided if I was going to look for more HP I would go for an Isuzu 6BD1T (5.8L) with an Isuzu 5 or 6 speed box mated to the LT95 transfer case that's already in there. You have to keep this transfer case for the 3rd axle drive. This is a much better motor than the Chev V8's. That way you wouldn't have to modify any driveshafts. A fair bit of modification required to do it but at least it is a known reliable drivetrain and an excellent motor in fact the same motor that's already in there with 2 extra pots. That way you could run 3.5 ratio diffs and not be overrevving the motor at 100k. The 6x6 chassis already has extra holes in the chassis brackets for moving the gearbox if need be. I am still running the standard 4BD1T motor but have upped the fuel a little and added a 3" exhaust and it runs much better but still wouldn't run 3.5 diffs efficiently. I just did a trip from Qld to WA and back with a fair load and pulling a loaded PT2 Haulmark trailer one way and it handled it ok. I have seen a couple that have done turbo upgrades and intercoolers etc and will then handle the 3.5 diffs but both have had turbo failures and I wouldn't go that way.
    Cheers......Brian
    1985 110 V8 County
    Queensland
    I have the 6.2 Chev in mine but only because it was easy to put an auto behind.
    Both autos couldnt hack it so the Isuzu MSA went in.
    If I was doing it again the Isuzu would be the choice as Bearman says.
    Keith
    OR....
    you could just work the 4bd1 thats in there....
    Irymple, Victoria, Australia
    Dave,
    what do you suggest to gain improved performance?
    Not that I am looking for any more out of mine, just curious.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Kingston, Tassie, OZ.
    Welcome and yes try and stay away from the v8 chev diesel....
    get it all in spec and then play with the fuelling and throttle stops to start with.
    then you need a better echaust and turbo.
    Feb 2011
    Rileys Hill
    Hi,
    On my 6 x 6 camper, I run the 3.5 diffs & 750 x 16 tyres. The motor & turbo are standard, the exhaust is 3". At 100 ks 2,700 2,800 rpm. It has been used a lot on & offroad. The worst thing is in high range 1st is to high when taking off up a slight hill. I need to slip the clutch too much. Apart from that it is great. Paul.
    Bearman's Avatar
    Hay Point
    Paul, how does your 6x6 handle hills with the 3.5 diffs. As I said earlier in this thread I just did a trip to WA and back with a fair load and even with the standard 4.7 diffs it just handled it ok. I know the 4BD1's are a torquey motor but I doubt that it would have handled 3.5's with the load I was carrying. Don't get me wrong, I would love to change them to get the revs down a bit and I already have all the centres and gears here to do it but still not sure it will handle it. I was thinking 4.1's might be more suitable. Do you ever get up this way (Hay Point, Qld) I would love to go for a spin in yours and experience the difference. Cheers......Brian
    Cheers......Brian
    1985 110 V8 County
    Feb 2011
    Rileys Hill
    Hi Brian, I have done 3 trips to Perth with a fair load. From Grafton up the Gwyder Hwy is the hilliest part of the trip. I can go up in 3rd gear most of the time as it just keeps pulling down to 1800 rpm. Apart from that I sit on 100 ks. If you are down this way you are more than welcome to have a drive.
    Paul.
