Results 1 to 6 of 6
Thread: Auslig 1:250K maps available for free download
    May 2002
    Heathcote (in "The Shire")
    <span style="font-size:12pt;line-height:100%">Auslig 1:250K maps available for free download</span>
    https://www.ga.gov.au/products/servlet/cont...DEFINE_PRODUCTS
    You will need to register, and supply a valid email address as the download link is emailed back to you.
    Once downloaded unzip and then import into Ozi via file|import maps|ECW maps
    Bushie
    Are these the same as the Auslig CD1 and CD2 that I bought?
    Ron
    Warburton, Victoria
    how big are the files????
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    they appear to be the cd version ones, they are not the dvd version one i am told.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    and the difference is....
    cd version has 35:1 jpeg compression
    dvd version has 4:1 jpeg compression
    dvd version has considerably much higher definition of exactly the same maps.
    I went through this whole process just before Chrismas. I wanted to download files from the site but at 2.5 mb per map and the you have 13 to 15 maps per section and 5 sections = 513 maps. It was going to be download havoc 8O 8O
    I believe then you have to join these maps together to run in Oziexplorer to keep the whole process together.
    There is a whole discussion in 'General Chat' about it...as the maps are free so why not illegally copy a set.
    BUT...I took Inc's advice and said 'Bugger it....just buy the DVD set'
    It is the best advice I have had for sometime :wink:
    The whole Oziexplorer/Natmaps/GPS works a treat and I am wrapped
    Lyndon.
