which variant of the defender?
generally.
you want the fuse close to the battery and you want to run both the positive and the negative back to the battery or to a major earth point such as the body earth strap or a body earth connection fitting and NOT an internal earth distribution block/junction connector itself as that can cause some issues in some circumstances with overloading the earth wiring from the block/junction connector to the body earth point.
