Thread: 12 Volt Fridge Repair
    PTC Guest
    Dose anyone know where i can take my 2 way 12/240 volt car fridge to be repaired around Sydney. It is an Ironman brand 50l and worked fine for years.
    I turned it on again the other day and the thermostat was stuck on 45 degrees. So i set it to 3 degrees and it kept on cooling all the way to the camp. Still reading 45 on the top. Even though everything was frozen solid. Then the next day i got the E1 error. Which indicated low voltage to the fridge and it shut down.
    So i plugged it into 240 Volts at home and the same thing with 45 degrees shown and then cutting out due to low voltage error.
    Any ideas on where i can take it. Will a fridge repair shop know 12 volt fridges? I have heard that Auto Elecs can work on them as they deal with car aircons. But is that true or is there someone that specialises in it? I have sent an email off to Ironman and they are yet to respond.
    Williams West Aust
    From my dark distant memory,is the Ironman a Waeco clone??? If so you need a Waeco friendly repairer,they seem to fix Engel OR Waeco not both.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Apr 2007
    Alternate Gas Refrigeration in Arndell Park (Caravan Camping Marine & Rural Refrigeration) do repairs for Waeco and Engel etc so they're probably a good place to start.
    2012 Discovery 4 SDV6 HSE
    2003 Discovery 2 TD5
    2003 Defender Xtreme
    1997 Discovery V8i
    an auto elec place will be able to but wont want to.
    A tech repair place that works in air con and consumer electrical repair is your best bet.
    from what you've said the most likely cause is going to be the temp sensor has failed and isnt giving the control circuit any info and thats sticking on full range.
    The fact that the fridge is freezing stuff eliminates all of the refrigeration stuff. so it should be a simple controller repair.
    Good luck.
    Brisbane,some of the time.
    More than likely the controller sensor is faulty.
    They are a cheap item,maybe worth trying to get one and replacing it first.
    Or if you can,measure the resistance and see if you can get any tech support to find out wha t the resistance of the sensor should be.
    Good luck.
    May 2002
    Heathcote (in "The Shire")
    Moorebank marine refrigeration
    They work on most 12v fridges
    Moorebank Marine / Liverpool Refrigeration Pty Ltd Unit 9,29 Helles Avenue Moorebank NSW 2170 Phone: (02) 9602 9571 or 9602 7936 Fax: (02) 9821 2242 Postal : PO Box 89 Moorebank NSW 1875
    Moorebank Marine/Liverpool Refrigeration - Low Voltage Refrigerators and Freezers
    Peakhurst Power Steering were a couple of doors along - very good with Landy power steering boxes.
    Martyn
    PTC Guest
    Thanks all. Yeah i do hope it is an easy repair. So i'll try out those places over the next few days and see what comes from it.
