Landy86,  looking with your eyes closed?  Suspension is probably the most talked about topic on this forum.
Have a squiz at Superior Engineering for a range of remote shocks.  You might find cheaper and just as good equivalents to Fox.  I know a few running the Amarda's without complaint.
As for coils if you have specs in mind give Dobinson suspension at call.  They have made 2 sets of custom coils for me for a 130.  Can't speak high enough for their preparedness to design and make a coil to my specs.  If you want the specs of my coils, troll through my build thread under Member rides, i've posted the specs for various coils fitted during the build. FYIW i believe that the D130 factory specs for coils is perfect for the D130, if you want lift find a set that have a longer free length with the same Lbs rates.
To get the best out of any shock in the 11" range you might want to consider SE super flex radius arms or an equivalent.  There is a fella on Facebook Garret Krampe that was designing radius arms with massive flex.
Something to be mindful of, a D130 bump stop clearance is about 25mm greater than a D110 (F&R) so any marketing quoting a lift might not be an actual lift in a D130.  I learned that the hard way when i fitted +2" coils and lost bump stop clearance to the factory coils.
Departing words, don't trust the marketing material of the after market coil manufacturers.  The only way to known how the coil will behave is knowing the specs: e.g. coil turns, wire diameter, free length, rate in lbs and compare to factory.  If they won't give that info to you, walk away.  I guarantee you what you buy isn't suited to a D130.
				MLD
Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
Gone: (Dorothy) MY99 TD5 D110
