Results 1 to 6 of 6
Thread: USB Plug in over head Console
    Jun 2011
    Oakleigh South Victoria
    Has any one tried to put a USB Plug in the over head console?
    Or even if there is enough power already up there that can be taped into, to run a USB plug?
    I'm looking at getting a dash cam and I hate cables dangling from the top of the windscreen. I was hopping if I could install a USB plug where the switches for the sunroof go, it would keep the cables out of eye sight.
    LRD414's Avatar
    Oct 2014
    Not exactly what you have in mind but here's what has been done for neat dashcam wiring installs:
    http://www.aulro.com/afvb/communicat...m-into-d4.html
    DISCO3.CO.UK - View topic - D4 left hand drive blackvue install guide
    (This one is left hand drive)
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    NSW Far South Coast
    Answer to your question is, YES. No problem.
    Sent from my Lenovo K50-t5 using AULRO mobile app
    Jun 2011
    Thanks ytt105,
    Have you installed a USB plug in the overhead console on your car?
    Do you have any pictures or just some advice as to which type of USB plug to use or which wires to tap into?
    Cheers Bruce
    You want it to run a camera, but I wouldn't have it poking out as a fitting...
    Fit a cable based one and have it sticking just out near the mirror.
    Offroad a USB will just vibrate out if inverted.
    NSW Far South Coast
    I wired in a cigarette lighter plug, then put a USB charger into that, taped the whole lot together so it wouldn't shake loose). Then put the whole lot up behind the light cover, (plenty of room). Just ran the charger cable out from under the light cover to where I wanted it.
    Can't remember which wire is ignition power but its easy to get to.
