Welcome aboard! Congrats on the new Rangie.
Having owned Discos before would prepare you pretty well for Range Rover ownership.
They are a great vehicle to drive, specially for long trips, very comfortable and safe on the road. Off road they come into thier own, very capable.
I've done a few snow trips and have seen other 4WD's sliding off the icy roads, but the Rangie is very sure footed as long as you drive it safely.
They are a lot of vehicle for the money, as long as you don't mind getting hands on with it when needed.
You really just have to tackle the fixing jobs as they come up, I've probably done almost every job on mine over 6 years, fortunatley most of the issues that do come up are fairly common and chances are someone else has already worked out a good way of solving them, which makes this forum invaluable.
Maintenance is the big thing, if you keep on top of the oil and various filter changes, you can save yourself a lot of headaches at the worst moment.
EAS is brilliant, but it does need attention every few years.
Bleeding the brakes is a big task, but can be done DIY.
Rave manual is a must, (you proably already have one for the Disco), as well as some way of reading fault codes if they arise. I have a faultmate MSV, not cheap, but I've been so glad I have it when I need it.
Good luck with it!
Cheers, Pete.
