Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: New 2018 Defender to share D5's Aluminium monocoque body.
    Jul 2009
    Well for those of you who are waiting to find out more about the all new Defender as a option for a more serious off roader and all rounder than the new and what appears at first glance city centric D5 here is some interesting news. The new 2018 Defender will reportedly share the D5's aluminium undercarriage so it won't have a full chassis, nor will it be steel.
    New Land Rover Defender - 2018 Land Rover Defender Coming Soon
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    St Helena,Melbourne
    1.13 MB
    I'm not Surprised to hear of a shared platform , it makes economical sense.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2009
    But does it make good engineering sense for what it's intended and stated use is and if serious off roaders don't believe it does measure up then whats the point?
    A D4 owner on another forum has mentioned that he recently did a LR factory tour and they had a new model RRS there with a bent sub chassis from being snatched. Suppoesedly the person doing the tour told them that you shouldn't snatch the new aluminium bodied LR's or you risk chassis damage. He recommended that when stuck you need to pull them out slowly without snatching.
    If correct then the new aluminium LR's are no longer serious off roaders.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D4 V8
    St Helena,Melbourne
    1.13 MB
    Lets face it, it wont be aimed at serious offroaders and the pricetag is likely to reflect that.
    1974 VW Kombi bus
    Brisbane,some of the time.
    Let's hope it doesn't also share wheel size,rear access set up and fuel tank size
    Williams West Aust
    Shame Mitsabishi still owns the rights to the word PAJERO
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    NSW far north coast
    Sounds like it'll be a life style accessory and not a work horse.
    Hmm, there's still the G-Wagen.
    NSW SW Slopes
    You people obviously haven't read that the new Disco has reinforced steel sub-frames.
    Sep 2012
    I'm not sure why everyone is worried about aluminium being used. As long as the engineering is done, there should be no problem.
    Brings back memories of when aluminium was first used for bicycles; everyone reckoned "steel was real", and predicted all sorts of dire problem with aluminium; none of which occurred. Of course the same problem when bicycle frames went from aluminium to carbon fibre...
    As for bending a chassis (or subframe) with snatching, same things will happen with a steel frame. And if I recall correctly, the current thinking of doing a snatch recovery is no longer a run-up and pedal to the metal, but more taking up the slack, then measured progress. Safer too, as less loading on shackles and straps.
    AndyG's Avatar
    AndyG is offline YarnMaster Silver Subscriber
    Jan 2014
    PNG
    As long as it comes in Keswick Green and 85 profile.
    Um I will almost old enough then to justify an auto.
    apologies to Socrates
    Clancy MY15 110 Defender
