Results 1 to 3 of 3
Thread: Tdv8 cranking battery recommendation
    Brisbane, Queensland
    Gday fellow L322 owners.
    I'm pretty sure my cranking battery is on it's way out. Any recommendations on a replacement and seller?
    I've found Varta L1 and Optima DIN 100.
    Also in case it's relevant I have a Traxide and yellow top in the back.
    Thanks.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    NSW SW Slopes
    Whilst I haven't checked the size, I'm sufficiently impressed with the Varta G14 that I fitted to the D4 to fit another to the L322 when the time comes. However I suspect that your vehicle doesn't have the same fickle charge management as the 3.0 TDV6 D4s and 4.4 TDV8 L322s so a cheaper battery may suffice.
    Canberra, Australia
    Understand that I am biased ... as I sell the batteries!
    I can supply Deka (or Federal) Intimidator AGM 9A94R @$410 delivered,
    Varta G14, an AGM battery @$418 delivered. Users have bought both, but Varta seems to be preferred.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
