Pay the reg, have your parents drive it once a fortnight, far better for the vehicle than sitting outdoors idle
 Master
						Subscriber
						Master
						SubscriberI'll need to store my defender from January to January, it'll be parked in my parents driveway and be unregistered.
Aside from the obvious things when mothballing, like a car cover, battery discharge, and preventing tyre deformation, I'm not sure what to do in term of storing dry vs wet.
If wet my parents could take it for a short drive every now and then (yes illegal, but we have a long driveway and on a cul-de-sac), but if it isn't bad for the car then I'm perfectly happy setting it up for total dry storage.
What things can go wrong in either situation? Which have you done? Anything that needs to be considered for Defenders is particular, internal corrosion perhaps?
Niels
Snowy - 1998 300tdi Defender 110
Past:
The Toad - 1992 200Tdi Defender 110
 Fossicker
						Supporter
						Fossicker
						SupporterPut it up on axle stands and it can be driven without going out on to the public highway. Put something like damp course between the axles and the axle stands. If it's to be stored outside open all of the days regularly to air it out and kill any dampness (might not be applicable to Australia). Wash it regularly to keep the crud and bird droppings from building up. A polishing now and then will protect the paint.
It's the moisture that ruins a sitting car, driving it, on the road, allows airflow and generated heat to remove the moisture, which is very damaging
Sitting cars deteriorate so much quicker than driven cars, unless stored in a dry shed....and by dry, not just undercover, lots of sheds have large amounts of moisture
Car cover on a car stored outside is possibly the wort thing you could do
I parked my 110 for 3 years on my uncle's farm (QLD) with no ill effects. Changed the oils before and after storage.
My uncle offered to run it once every few weeks around the farm but it probably wouldn't have gotten hot enough to boil off the moisture from the engine, so I instead opted to leave it sit. Repeated cold starts are tough on engines and soot up / acidify the engine oil.
If your parents can give it a proper run on the highway to get everything up to full operating temps that probably would be the best option though.
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberFor a nominal fee, I'll let you store it at my place as long as the rego is paid and there is sufficient fuel provided to take it out on weekends (purely in the interest of keeping things ticking over OK).
I know, I know, generous to a tee that's me.
Deano
 Master
						Subscriber
						Master
						Subscriber Master
						Subscriber
						Master
						Subscriber| Search AULRO.com ONLY! | Search All the Web! |
