Hi,
Same problem here, plus water building up with the duckbeak valve blocking with vegetation crud.
I loosened the intake duct and repositioned the foam gasket between it and the heater intake. It is not a good fit, and difficult to get hands in there. However, not having the gasket hanging down towards the road has markedly improved the warm engine bay air problem.
An air ram cowl on the fender top would possibly also improve the fresh air flow vs engine bay air, just using the fan only brings in more warm engine bay air.
While you have your hands in there, clean out the duckbeak drain at the bottom of the well. The rotting vegetation can get quite stinky.
It is only a problem in warm weather, and the air conditioner can cool things enough, but it should not have to.
Sent from my GT-N5110 using AULRO mobile app
