Remove your gear stick. You will find that LR used weights which are kept in place with grease. Chances are they need to either be re-greased or cleaned and glued in place (permanent fix). Hope that helps
Sent from my SM-G925I using AULRO mobile app
Hi all, just wondering if any of you Puma owners have experienced any noise issues with the gearbox, especially while towing, when the engine is developing full torque?
The noise is a gear harmonic/resonance (like a low gear chatter/rumble resonating low frequency) which seems to be coming from the gear box area. It only happens when close to full torque in 5th or 6th when towing or climbing a very steep bit of hwy.
I had my clutch replaced under warranty because the rivets came loose at 55000km, at 78000km I've noticed the clutch rattle coming back when cold, which is how the original started. Just thinking that this may be related?
Any thoughts?
what are the weights on the gearstick for?
guess they would be on my ranger.....same engine,,,same gearbox
 Master
						Supporter
						Master
						SupporterIt sounds like a problem may be starting with 6th and I suggest not towing or heavy loads in 6th until the issue is resolved, This is an overdrive gear and will most likely lead to a major gearbox problem.
I always use 5th if I have a full load or up a steep hill with my 130.
Ian
Bittern
