Results 1 to 10 of 12
Thread: Oil Viscosity Comparison
    WA
    This may be of interest to some. The viscosity is on a log scale, so the difference between the lighter "transmission fluids" and heavier gear oils is quite a lot.
    http://www.aulro.com/afvb/attachment...on-oil_vis.jpg
    Safety Bay
    Whats the difference between Auto Transmission Fluid and Transmission oils?.I ran ATF for 400K(transmax M) in my R380 and MTF(Redline MTL) for the last 100K.I changed because the ATF was grating in really hot,40C temps were's MTL has been fine up to 50C,the hottest I've measured it in. Pat
    WA
    Quote Originally Posted by PAT303 View Post
    ATF is a bit lower in viscosity than the (other) transmission fluids. When I get a minute I will add it to the graph. The slightly increased viscosity plus better additive package in the MTF type fluids are why they work better at high temps.
    I was most surprised that 15W40 engine oil is slightly more viscous than EP90.
    May 2014
    Tamworth NSW
    Can't remember whether I saw this here, or elsewhere, but I found this interesting.
    Shows viscosity differences between various oil weights at low temperature
    http://i.imgur.com/ZK5VcgM.mp4
    -Mitch
    'El Burro' 2012 Defender 90.
    Jul 2015
    Taupo NZ
    I was most surprised that 15W40 engine oil is slightly more viscous than EP90.[/QUOTE]
    Very interesting, thanks for that. Can someone explain in simple terms, how the engine oil can be more viscous when it appears to be so much 'thinner' than EP90? To a layman like me?? Does it hold it's consistency at temperature, better than the 90 does? Cheers.
    WA
    Quote Originally Posted by Gordie View Post
    I am not sure engine oil appears "thinner" - it is just that you probably have never tested them side by side on a viscometer, or maybe you are confusing density and viscosity.
    The rating numbers / system used for engine oil are different than for gear oil.
    E.g. if you compare Castrol mineral EP80W90 vs Castrol RX super 15W40, the pour point of 15W40 is -33*C, whereas the EP90 is -35*C, so right across the full temperature range it is slightly less viscous (i.e. thinner).
    Jul 2015
    Taupo NZ
    Smile
    Thanks mate, that does clear it up a bit for me, I think I might have had the density confused with the viscosity.
    I found the Penrite Light Gear Oil to be too thick in my LT77, making gear changes very baulky.
    When I compared Penrite Oils data sheets, I found that the Synthetic ATF was a lot more stable at higher temps than the Light Gear Oil; so used that for a long time in my R380.
    After decades of Penrite use, I have now found the Nulon Light Gear Oil to work really well on the R380. More viscous than the Penrite ATF, without the selection issues of the Penrite Light Gear Oil.
    Safety Bay
    I'm trying to decide which way to go as my R380 will hit 500,000km's in a month or two so needs a flush and change.I'd like to stay with MTL but a lot more choices are around now. Pat
    WA
    Quote Originally Posted by Michael2 View Post
    Which Penrite oil are you talking about? They have several semi and full synthetic manual transmission fluids, and they all have different specs.
    e.g. their 70W75 full synthetic fluid is very similar in viscosity to ATF
