Results 1 to 9 of 9
Thread: What coolant do you run in your RRC?
    Western Victoria
    And why?
    WA
    1) Tectaloy 60 or 90 or whatever the green stuff is.
    2) Because I can get it up here!
    At any given point in time, somewhere in the world someone is working on a Land-Rover.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    bmw branded blue stuff
    cause that is what the previous owner was using and some concentrate came with it
    ps cant look at the details as it is in the shop getting a transfer case swap...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Adelaide - Torrens Park
    Caltex green concentrate mixed with demineralised water. Because I keep it at work.
    Gosnells
    The GREEN stuff, Not the Cheep Brands, at highest concentration suggested and mixed with de-mineralised water.
    Because it's relatively cheap to replace often, and LR recommends it, as did VW/AUDI and it performed perfectly in my 600K Passat... and ANY leaks are easy to find with a UV torch/light source, fresh or dried tracks AND glycol has a most distinctive odour...
    The Lady Sarah, 3.9 Vague SE with working air suspension.
    Western Victoria
    Quote Originally Posted by Davo View Post
    Tectaloy 60
    That is what I am currently using. The premix.
    I bought it because it mentions "protection against aluminium corrosion".
    It has gone off and I will be refreshing the coolant. I could continue to use it. It is a type B conventional coolant.
    Tectaloy 90 & 100
    Type A organic coolant. The green is silicate, phosphate & amine free.The red contains Ethylene Glycol 369g/Litre.
    I assume I should be using type A and not type B. Would this be correct?
    Now, I have a few bottles of Penrite concentrate. It is green, type A HOAT.
    7 YEAR 450,000KM GREEN CONC
    350,000 KM GREEN CONC
    They also make a type A OAT.
    7 YEAR 450,000KM BLUE CONC
    8 YEAR 500,000KM RED CONC
    Now, I have a number of aluminium block vehicles with copper/brass radiators and, now doubt, steel bits. Sixes and eights.
    Would these motors have any issues with the Penrite coolants listed above?
    Quote Originally Posted by BigJon View Post
    Yep. Used to use that all the time on Minis. Back when times were simpler.
    Dec 2014
    FNQ
    Blue mb coolant aka febi lemforder vaico.. because i have enough bottles of it.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Snagger Guest
    I use the pinky-orange stuff, as it's meant to be better for the alloy parts of the engine. As I understand it, the green stuff is meant to be for iron or steel blocks and heads.
    Oct 2003
    Godwin Beach Qld
    I use "Castrol Radcool Concentrate" in a gold coloured 2.5ltr container, our 300TDI disco 1 has the red stuff in it after the head was replaced by M.R.automotive after a failed temp sender.
