I just cut off the trumpet, and eventually changed to a shorter defender style when I put the snorkle on.
What are people with dual batteries in their classics doing for air filtration?
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
Michael T
2011 L322 Range Rover 4.4 TDV8 Vogue
Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
Just remember to put an AGM battery in that tray, as the MAF doesn't like acidic vapour.
I made up a fibreglass vent over the top of the battery and cut a hole in the radiator support.
After a friend swamped his motor on just a country road I then got a snorkel.
Regards Philip A
Yep cut the trumpet off
I never had a problem running a lead acid battery![]()
thanks
now to find one![]()
You can get a bigger battery in by flipping the radiator bracket and cutting a bit off the side of it.
I forget the details not as it was 11 years ago but it is pretty obvious what is needed.
Regards Philip A
excellent!
