Results 1 to 9 of 9
Thread: shockies
    Oct 2014
    Northern NSW.Australia
    shockies
    Got a good price for new Monroe shocks.
    Front 16-0198
    Rear unknown, as none listed, for SWB.
    My other series 3 has 16-0208 on the rear.
    Anyone using them and confirm the above rear, is ok for SWB.
    Thanks.
    whitehillbilly
    Irymple, Victoria, Australia
    Shane, front and rear on SWB will interchange, 109's have different rear shocks.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Oct 2014
    Thanks Mick.
    original front and rear have different shroud length and parts number.
    original rears are different length, longer, I thought.
    You saying NEW Monroe's rear and front can be same part number, so the same ????
    shane
    Yes they will fit.
    SHOCK ABSORBER (REAR) S2/2A/3 88" heavy duty up to 1984 & S1 107/109 heavy duty 1954 onwards & (FRONT) ex-military S2/2A/3 109" up to 1984
    From an online parts catalogue.
    Shane maybe the rear have a bit more travel, hence the above fitting the front of an ex-military 109, as the ex-military (Aust.) have longer shackles.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Oct 2014
    Thanks Mick.
    A it more info I can go in with.
    They probably have listing for LWB front shocks.
    Whitehillbilly
    I have a full set here from my 2A 88, so I will have a play with them today and see if the rear extend out further or if there is any other difference that I can pick up.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Oct 2014
    Had a look on my other series, with Munroe's fitted.
    Found the number on the rear and took some measurements, as the axle straps are fitted.
    The Front is different to the rear, but will call to town Monday with the new found rear numbers.
    Once sorted, with post the numbers.
    whitehillbilly
    Two inches difference when fully compressed.
    Ten and a half inches between the centre of the eye, versus twelve and a half inches.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Oct 2014
    Thanks Mick.
    Got the numbers off the rear shocks, ( Monroe's ) fitted to my other SWB
    when I got the new ones , they were 2 inches short of the bump stop when fully compressed.
    Spoke to my mate a Repco, where they came from and is going to look into it AGAIN, as his mate is at Monroe.
    Getting closer to sorting itout.
    whitehillilly
