Hi Isaac , It sounds like you have covered all bases . You could try adjusting the thread on the clutch master cylinder . Remove those 6 self tapper screws , and take the little plate off , there should be a 13mm lock nut and two 13 mm nuts each side of the cylinder/peddle rod . You can wind it in or out , give that a go . Note where it was to start with in case you have to adjust it back !!. Jim
