Results 1 to 10 of 13
Thread: D3 - Roof rails & cross arms
    Jul 2012
    Toogoom, QLD
    Folks,
    I have a 2007 D3 and want to get some roof rails and cross rms. It has the tracks under the plastic strips.
    Does anybody have the LR part numbers for these please?
    I did a search but could not find what I needed.
    thanks in advance.
    Peter
    Jul 2012
    Toogoom, QLD
    Found them on both fleabay and Rimmer Bros
    VPLAR0074 Roof Rack Side Rail Set - Extended Length - Full Length of Roof - Black Finish - Genuine Land Rover $568 AUD
    VPLAR0001 Discovery 3 & 4 Roof Rack Cross Bars - Pair - Genuine Land Rover $350
    Fleabay the guy wants $849 for the rails & $529 for the cross arms
    Think it's cheaper to go with Rimmers!
    Jan 2015
    I bought the VPLAR0074 genuine rails locally from a dealer. I rang around looking for a deal and paid $700 versus a normally quoted >$1000
    Given the size of them, with the shipping costs from Rimmer Bros you'll probably end up around the same money...
    Not sure of your application but the genuine cross rails have a limited useable width compared to say Rhino bars (e.g. VA137) so that may be worth considering too
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Jul 2012
    Toogoom, QLD
    Thanks mate, I'm still considering options. Stealers up here charge a fortune for any part so have not even tried them yet but will do so.
    As for the cross arms I only want to hang an awning on them, one I can remove easily. Have not even looked into how to do that yet.
    Jan 2015
    Quote Originally Posted by PeterOZ View Post
    For that purpose I think you'll find Rhino cross bars will work better, as the LR crossbars arms go inboard a bit before you have a slot to attach the bracket to where the Rhino bars overhang may work better. Different to the pic below, but I ended up mounting my awning under the crossbar - worked well.
    Rhino
    OEM
    HTH
    David
    Last edited by l00kin4; 1st November 2016 at 10:48 AM. Reason: line spacing, added info
    Jul 2016
    SA
    I have a set of short rails and cross bars taken off my D4 if you are interested PM and I'll organise photos.
    Williams West Aust
    Folks,
    thanks in advance.
    Peter
    Peter.
    There are no rails under the trims.You need the rail plus the cross bar if you need adjustable bar position.
    Look up the Rhino website,as you can get the Rhino bars that bolt direct to your roof so the rails aren't needed.The downside is you can only fit the cross bars where the roof fittings are.Have a look at the trims,where the plastic fixtures are is where the roof fastenings are.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2012
    Toogoom, QLD
    All sorted and fitted a few weeks back, took me about 2 hours all up.
    Williams West Aust
    How do you like the Kings awning????
    I will be looking for one into the future.
    They don't spontainously combust like the fridges do they???
    Not having a crack at your awning,genuinely interested in the quality.
    they say heat causes cold but the reverse is
    Andrew
    Jul 2012
    Toogoom, QLD
    For $118 delviered it seems pretty good! If I get 2 or 3 years out of it and it falls apart I'll buy another one.
    Some of the other 3 letter suppliers want stupid money for a bit of alloy and canvas!
