                                                2nd November 2016, 02:45 PM
			Newbie Buying Tips--'94 Defender 110
					Just joined today--see intro
 I've purchased my airline tickets to (hopefully) go purchase my first Landy in Townsville this coming Tuesday.
 Please give me your top 3-5 items to inspect to ensure I don't ship home unforeseen issues.  Also, does anyone know where I could check all VIN numbers to ensure they match?
 1994 Defender 110
 200TDi/5 speed
 160,000K
 Original owner selling
 No mods other than bullbar, roofrack, sidesteps
                                                2nd November 2016, 04:10 PM
					Hi mate and welcome.
 Rust will be the #1 problem for a QLD car.
 The main hidden rust trap is between the gearbox cross member and the chassis, so take a good look there for signs of rust 'weld' or swelling between the crossmember and chassis. If its bad, its a big job to fix - potentially rendering the chassis a write off. Take a torch and something to poke around with ( that you can get past the x-ray machine at the airport :-)
 Second area to look for rust is the firewall - look very closely inspecting footwells, the seam under the windscreen and the door hinges/ door pillar. Footwells can be repaired, but bad rust in the door hinges, door pillar or on the firewall is once again, a big job.
 Third area for rust is the rear cross member. Get under the truck and look back to the  backside of the rear crossmember- especially the joint between the rear cross member and the chassis.
 Lastly - look closely at the doors - they rust out. if they don't close well, have gaps in the frame, or are rusted out on the bottom edge they could be past recovery - replacements start at $500 each.
 Good luck !
                                                2nd November 2016, 06:25 PM
					Thanks Andy.  I plan to take this one back to the States with me when I return...will certainly restore it someday, but would like to avoid as much rust as possible.
