Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: TDV8 Auxiliary Belt Refit Help
    Golden Beach, QLD 4551
    Evening All,
    I have the 3.6 TDV8.
    For some reason the water pump pulley has come loose and sheared the bolts off.
    I have refitted with new bolts but am having a hell of a job getting the belt back on.
    I have the correct way/direction/location of the belt fitting on the pulleys but cannot get it on. With the tensioner all the way back it just is too tight.
    I would appreciate thoughts or ideas on how to refit this belt!
    Thanks in advance.
    Chilly
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Chilly View Post
    Evening All,
    Thanks in advance.
    Chilly
    Are you sure the bottom of the belt is sitting correctly in the crank pulley and not riding on the edge?
    I have struck this on a couple of vehicles in the past. Reason some one before hand has fitted the wrong belt. Goodness knows how they got it on in the first place though I had this on a Nissan pulsar timing belt and also on a TD5 Defender , a customer took a belt off and refitting it it wouldn't go back on, they had to undo the A/C compressor bolts to allow the compressor pulley to tilt forward slightly to gain a 1mm or 2 to slide the tight belt back on.
    I had a look at Microcat and I think this is how the belt should be routed.
    NSW SW Slopes
    Thanks for replying.
    Yes to belt being on the pulleys correctly....have checked many times whilst trying the get b lt on! Pretty frustrated as you may guess!
    Thanks for that. Confirms I have it correct.
    Well, still having no luck getting this belt on. Seems way to tight.
    Feels like some how it has shrink!!!
    NSW SW Slopes
    Are you trying to slide it over a smooth, edge-less idler pulley or over one with ribs and an edge? The large idler pulley (#7) would be my choice as the small one is too close to the water pump pulley.
    Tried both
    Tried different pulleys etc. belt is just so short compared to Alternator belt to put on. Have got it correctly, as per topic, on
    NSW SW Slopes
    At least your engine has a tensioner - my 4.4TDV8 doesn't for its stretch belt that requires a tool to run it on.
    Does the tensioner have to be reset?
