Results 1 to 10 of 14
Thread: AMV Centre diff lock activators
    Sith Guest
    ok , are these al that they are cracked up to be ? had a quote from ARB to fit one up $700 :?
    and good v's bad feed back ?
    Gold Coast, Qld
    Got one in my D2, and it is great. Have now fitted a switch which turns off the CDL light to enable me to turn the engine off and on to disengage TC & ABS when I need, then simply flick the switch to the CDL light and all is how I need it. Before I had to turn off the CDL, run the car back and forward a few times to dissengage the CDL (sometimes not possible in a tight space) turn the engine off and back on to turn off TC & ABS and repeat turning the TC & ABS on again.
    $700 sounds about right for ARB to do it. From memory I paid about $620 for a LR mechanic to do it.
    Best mod to date though!!
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Ferntree Gully VIC
    Re: AMV Centre diff lock activators
    mate not sure of your location, but if you are in Melb [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    give glen a call at RoverLand 9758-5777in regards to the CDL unit :wink:
    130's rule
    Pennant Hills, Sydney
    I fitted mine a few years ago not to hard to do yourself mine is the amv model makes it a better vehicle off road
    Sith Guest
    Yeah im in Fremantle W.A. so i really only know of ARB over here .. and im none too handy [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    damn i am bustin to get stuck into it :wink:
    Williams West Aust
    Hi Sith
    I made my own CDL acuator using socket set extensions and unijoints purchased for $2 a piece from cash converters,wouldnt of cost me more than $30 all up,and works a treat.
    If you happen to be traveling thru Williams at all give me a yell you can have a look.I will find my post on how I did it and BUMP it up for you.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Stockton, NSW
    AMV kit
    Hi,
    I have one, well had one in my car, its currently out as i am having some problems with the CDL mechanism in the transfer case.... according the mechanic that fixed it he thinks it has something to do with the AMV kit, but i highly doubt it.
    I fitted mine myself, its not hard, but you would be best off to come in from the top i think, first time i did it i come up from under the car and it was nearly impossible to contort my arms up and around to the top, my arms are to round, might be ok if you have skinny arms though. when i took it out i just pulled out the centre console and tranmission tunnel cover, much easier to reach the bolts and cables!
    Will we are on this topic, does anyone have a picture of the little lug on the top in the locked position? i am having some issues with mine AMV kit now i am puting it back in, the dog isnt turning far enough to trip the magnetic switch. I am not sure were i have gone wrong...
    tombraider Guest
    Guys the aftermarket kits are sh*te Shocked
    Go to www.discoparts.com and email the owner (Mark Casey)
    tell him Mike Hayes from D2AU (Australia) said to contact him.
    He will sell you the factory CDL lever assembly from a D2a for approx. $500.00 landed.
    Then you end up with the proper cable operated D2a Lever with high low and lock on it.
    Bolts straight in, no messing around.
    And far more relaible than a wiper motor or solonoid system.
    Mike
    Not sure if this is quite on-topic, but thought it might interest you folks.
    http://www.lrexpert.com.au/specials.php
    Graeme Cooper has a manual kit on sale $410.
    <div class='quotetop'>QUOTE</div><div class='quotemain'>This is a manually operated centre diff lock kit to suit a series 2 Discovery, manual & automatic TD5 or manual V8 only. This will operate in high & low Range.[/b][/quote]
    Looks very similar to the button cdl in the old Countys.
    Simon
    tombraider Guest
    He's just re-selling the Les Richmond Kit.
    Why not for around the same $$$ have a neat factory lever assy.?
    Takes about 7 days to get here for $500.00 or there abouts
    From LR aust they are $1500 but Marks a good guy there. I've sent 3 people to him now, and we are all very happy with the service and the product.
    Believe me the convenience of just push left/right is far better and neater than 2 levers/switches
    And I've seen several electric operated versions fail. Especially after a wet trip and then no use for a week or 2....
    Cable actuated, simple, reliable, quiet, neat!
    Mike
