Results 1 to 10 of 24
Thread: Water tank woes
    Tangambalanga
    Unhappy Water tank woes
    Have had issues with the water tank (80Lts) in the Coorong Camper since just after we first picked it up. They said they pulled it out, checked it, and everything was fine. Tank wouldn't fill properly, and the water comes out tasting fowl to put it mildly. Have tried cleaning it with vinegar as well as a "Tank Cleaning" product several times, but all to no avail.
    So the other weekend, I bit the bullet and pulled it out myself in order to try and see what the problem may have been.
    The only thing I noticed that I didn't like, was the rust on the gauge that's inside the tank,,, rather unusual I would have thought,,, being stainless and all The other thing I noticed which I'm unsure about, is the use of solder through the joins, but I wouldn't expect that to be an issue, as Gal tanks have had this for years.
    So, having cleaned it out, testing it before I put it back in, giving it a quick test upon filling it four days later, finding nothing wrong at those points, felt good about it.
    Camping last weekend up at Avoca (Amphitheatre), go to make a coffee,,, and ahh crap,, same **** different day.
    So now, I'll be replacing it with a brand new one.
    Don't know at this point whether I should try another stainless one, or whether I should go plastic.
    Any thoughts gentlemen,, ooh, and ladies
    Aug 2010
    Sunbury, VIC
    Yeah, that's been weird ever since you've had it. The plastic tank in the caravan only starts to taste funny if the water sits there for weeks, but fresh water in it each time is fine. That's decades old, so my experience says go plastic.
    I'm sure others will have other thoughts.
    Western Victoria
    Solder?
    Sounds strange to me. I hope they used a silver solder and not lead.
    Maybe the solder is leeching into the water. If it were mine, I'd use a plastic tank with suitable protection from stones.
    Mar 2014
    Romsey Country Vic
    What are you using to fill it ?
    A garden hose will make it taste like ... We'll never mind it's tastes like garden hose .
    Get a food grade hose and try it .
    Also rinse the tank with either vanilla essence , I carb of soda or cheap option ...red cordial .
    In my experience steel , whether stainless or not will taste " funny " plastic is a safe bet .
    Oct 2014
    Water tank woes
    My stainless tank has never tasted funny but always filled using food grade hose. However I am changing to plastic due to leak issues at spot welds. Plastic can also taste wrong if incorrect plastic used.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Tangambalanga
    I did wonder about the type of solder used, but this is the first time I've ever had taste issues with stainless, but I have had it with plastic. That being said, it has been a long time since I've had a bad taste from plastic, but then again, I generally only have the bottled water especially these days.
    Is there a better type of tank to get, or will most RV/Van places just have the right units?
    Free Again Thanks Dan
    My camper has a plastic tank and when we bought it new in 2011 our water the first time we used it tasted like Polystyrene
    We flushed it a couple of time`s using the bi- soda trick and all good since.
    I never leave water sit in the tank when it is not in use , Although i do use a garden hose to fill it with no strange taste so that is myth busted at our place
    Jun 2008
    McMinns Lagoon NT
    Can't throw any definitive light on your tank issue although lead in the solder may be a possible one. What about the actual lines/pipes/hoses? I would assume that it wasn't caused by the pump.
    As a tank cleaning product I have never used anything but citric acid (usually powder but on occasions actual lemon or lime juice). However our 2 x 60L poly tanks on the Adventure were never a problem and were filled by the closest garden hose for over 10 years.
    The Kimberley only has 1 x 70L tank and so I have been investigating additional options. Send a PM and I can give you every website link in Australia.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Avoca Beach
    Funny I have met several people in my travels who have had camper trailers with stainless tanks that have split open, usually at the baffles.
    The theory told to me by one is that the weight of water causes the sheet to flex , work harden then crack, which calls into question the practice of using stainless for water tanks regardless of how attractive it is in theory.
    On the other hand my bog stock 65 litre plastic tank soldiers on, although one did wear through after about 12 years including lots of off road and had to be replaced for the princely sum of $85.
    Regards Philip A
    DiscoMick Guest
    Yep our plastic is 14 years old and fine, but I keep it empty when stored and flush it regularly. Just use a garden hose to fill it.
    Sent from my SM-G900I using AULRO mobile app
