Results 1 to 10 of 18
Thread: Isuzu MSA gearbox into 6x6
    Queensland
    Many years ago now I fitted an Isuzu MSA 5G gearbox into my 6x6 Camper conversion of a prototype project Perentie chassis.
    Sheldon designed the adapter housing to the LT95 T,box to keep the 6x6 facility.
    All has been well for thousands of K,s untill the last trip the box started to get hard to change gears in. We got home with only 4th gear selectable.
    I suspected the nut on the end of the mainshaft had come loose and on inspection I was right.
    My fault, I had not staked it deep enough.
    Buying a WSM it states the first of them were not staked at all.
    Then they staked into one groove and the latest are staked into two grooves.
    This leads me to believe there was a problem with this nut working loose.
    I have just swapped to a spare box and while everything is out thought I would post a few photos of how it looks.
    So if you want to ditch that LT95 and go for a 5 speed for your 6x6 this is how its done.
    Sheldon might do you the housing or make your own.
    Oct 2014
    Salisbury Downs, SA
    Thanks mate, I have a similar setup 4bd1 msa and series transfer box,, nice to get an idea of what it looks like off.
    Queensland
    The extension housing has a division with a seal in it.
    Bolted up.
    Drive flange on. And made sure its staked this time
    Last time I staked it through the back. This time I drilled and tapped a half inch hole above where the nut is and staked it with a blunted small cold chisel.
    Adapter flange bolted up.
    Keith
    Sep 2013
    Darwin
    12.74 MB
    Thanks for posting 123Rover50.
    I'm probably not understanding something. How can the staked nut in the photo be responsible for gear change difficulties? Working with my setup the nut would seem to be there simply to hold the drive flange in place.
    The photo perspective had me fooled, but I now see the grooves in the adapter are very coarse by the peaks just in the right of frame.
    Queensland
    Quote Originally Posted by workingonit View Post
    You are right. I dont understand it either. The nut had worked loose and I thought that may have let the shaft move back and forth.
    Something has worn because the rearmost gear has about 4mm of end play whereas the replacement box gear has only 1 mm or so.
    Queensland
    The LT 95 WSM states the spacer and transfer gear should be locktited to the shaft. Of all the boxes I have stripped not one was tight and all showed some flogging of the shaft splines.
    This time I thought I would cut some grooves to make it easier for oil to get in and see if that makes a difference.
    Keith
    Hay Point
    Just looking at the spline wear in the shoulders of those gear splines I wouldn't reuse that gear Keith. It is going to have slop there when you accellerate/decellerate unless you loctite it. Even with loctite it will probably eventually loosen. It's important to loctite the sleeve/spacer as unless you do it will remain stationary inside the seal while the shaft turns and act like an oil pump and transfer oil from the transfer to the gearbox. I would also check the mainshaft splines for wear where the gear sits on it.
    Cheers......Brian
    1985 110 V8 County
    Hay Point
    I had better rephrase my last post - the transfer oil will end up in the adaptor instead of the gearbox as I stated!!!
    Any chance of a photo of the front of the T/C where the adaptor bolts on Keith?
    Did you machine/drill the front yourself or get someone else to do it.
    Cheers......Brian
    1985 110 V8 County
    Sep 2013
    Darwin
    12.74 MB
    I'm a novice re contact patterns, but the top photo seems to show the contact is well inside the tooth length; yet seemingly worn at the other end. Mismatching contact due to worn shimming?
    Queensland
    Quote Originally Posted by Bearman View Post
    I cut it off with an angle grinder, then sat the back end on the mill table and milled it flat, and square. Here is a pick of when I set it up way back when I was putting the auto box in it.
    Dont have a pic from the front sorry.
    Keith
