Results 1 to 6 of 6
Thread: 130 tray/Canopy fitment.
    Dec 2010
    Batemans Bay mostly, and Brisbane
    Hi Everyone, Colleagues, gentlemen, ladies and random viewers..
    Just thought I'd post up some images of the tray and canopy I have just recently completed fitting to the 1996 130 crew cab.
    The tray and canopy are as labelled, an Hockney-Alcan modular measuring 2050 by 1800. the canopy is a 'Lowline' steel frame alloy skin. These items were originally fitted to a Rodeo extra cab- and being a painters vehicle yes there is paint everywhere...
    I managed to convince the GF to paint and insulate the inside of the canopy frame. There is a rack that was fitted to the canopy but it now has to be fettled to attach- too long, lots of surface rust. It is an original Lowline item. this make seems ok - with evidence of attention to joint welds and frame strength and good access.
    I considered making a frame and canvas canopy for the old Duratray originally fitted to the car but elected to do otherwise. I can always paint and modify this frame and tray- canvas is a bit delicate after exposure to weather and then there's cost....
    All up this cost $1370. $1K for the tray and canopy delivered eBay special ( I waited a while for something to come up), extra to convert mounting arrangements with 100x50 3mm wall C section (longitude) and 6mm wall alloy front width section. I couldn't use the original mounts nice as they seem- these were not up to the job of flex and load bearing on this chassis by my judgment.
    Before anyone comments yes I know I have destroyed my departure angle. This is intended to be overland touring arrangement. I still have 'some' departure angle if I take the towball out....
    I was also given a lot of fasteners and alloy right angle brackets by the GF son whom fits solar panels. I can say how immensely useful these were to the job. Now I have to figure out how to repay the favour.
    Alice Springs
    They don't work.
    Jun 2015
    Darwin, NT
    Can't see the pics bro.
    Apr 2015
    Wellington NZ
    Talking
    No pics there fella........
    Dec 2010
    here they are folks. Seems I haven't mastered insert image procedure.
    aluminium c channels.
    from past experience I would put some more stiffeners under the aluminium c channel. normally there is a bracket near the back of the tray that supports the end of the channel. current config has them canterlevered a long way so if they bend it gets embarrassing.
    Second thought. Another length of C channel bolted back to back. Pickup from the 3rd set of bolts from the back extending to the back.
    hope this helps.
    Last edited by dromader driver; 19th November 2016 at 12:14 PM. Reason: 2nd thouht.
