Thread: 4cyl D5?
    May 2003
    On The Road
    4cyl D5?
    at 500nm?
    can anyone say 4dbt?
    and we all know how smoooooth they are,,
    should be a nice car.
    Remember 350hp V8s from the 4BDT era?
    Seen the silky smooth idle of a 400+hp modern V8?
    With the tech it's likely silky smooth..
    Brisbane, Queensland
    The lower output motor has a slightly better power:weight ratio than the Prado. It will be interesting to see how it drives.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    99.87 MB
    I wonder if the Ingenium SD6 will be putting out 265kw/750Nm.
    Slunnie
    Nov 2008
    Knaresborough North Yorkshire UK
    Seen some trade press which says Ford is trialling the new SD6 Land Rover engine in the F150. Not sure how that would go in US market however might be an export option.
    Western Victoria
    You obviously can't.
    Unless you have an earthing problem.
    https://www.civicsolar.com/product/i...p-ss-screw-1pc
    May 2003
    On The Road
