Thread: 6/7 seat options ?
    May 2008
    Bundaberg Qld
    6/7 seat options ?
    Are there any options/experience for adding a 6 (or 7) seat to a L322 ?
    TIA
    G`day ,
    when we were looking there were a couple of 6 seaters a single in the back.
    Noticed this one and it`s 7 seater .
    http://www.carsales.com.au/private/d...r-Range-Rover-
    2003/SSE-AD-4116550/?Cr=2
    I see the link shows gone but if you look on carsales its a 2003 in Toorak it`s V8 its Vic reg is RVOGUE
    http://www.carsales.com.au/private/d...-4116550/?Cr=2
    Feb 2014
    Overfinch in the UK use to make them, they are rare now though and not cheap.
    They were a rear facing folding bench that used the original rear seatbelt mounts
    May 2008
    Bundaberg Qld
    After much homework and many phonecalls, the simple answer appears to be no. The aftermarket seat people do not have one for the L322 and none of the local blue plate guys will touch it.
    Queensland
    Seen this? MY12
    http://www.carsales.com.au/dealer/de...13900894/?Cr=0
    Recent model so assume whoever put seats in is still around - worth calling the owner?
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Canberra, Australia
    looking at the adverts for the 7 seaters ... no mention of what they have done about the spare wheel. Looks like you would loose the access when you installed the seats.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Aug 2015
    Coolamon, NSW
    Quote Originally Posted by CSBrisie View Post
    Seen this? MY12
    Also has E-Diff apparently
    - Justin
    Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
    Moved into MY12 L322 4.4 TDV8 Autobiography
    VK2HFJ
