Results 1 to 2 of 2
Thread: 2002 TD6 air suspension inactive/ hdc inactive
    Feb 2009
    Bondi
    Hi All.
    Anyone know what 'camber alert or error ' means on the fault tool.
    I am trying to clear the Air Suspension/HDC Inactive messages.
    The suspension was down on one side, but has returned back to to the normal height today since fitting a new air strut yesterday......but not straight away.....
    All the lights have come back on the suspension height panel, and up/down knob......i am baffled......
    The camber message is confusing.
    Cheers Paul
    Aug 2010
    Sunbury, VIC
    If the system faulted because of a knackered air bag, you will need a diagnostic tool to clear that one. The camber fault means the calibration of the wheel heights is wrong or one side is up or down further than it is being commanded to be. Clear all your faults and see if it levels up properly, and check your wheel heights - read from the ECU so you know what the car thinks the heighs are.
