Results 1 to 9 of 9
Thread: Is my logic sound?
    Aug 2008
    latrobe valley victoria
    Is my logic sound?
    I've just done some work on my head ( valve grind head gasket seals and rocker shaft with less wear) now I have an intermittent issue with starting.. it either starts first or second push or not at all after 2 try's , whilst looking at the battery charger I noticed there's a fair draw being sucked out of the battery.
    Would it be sound to start looking at the battery basically not being sound enough to get enough charge from the generator to get enough speed up for the engine to fire, or to replace what was drawn from it by the generator whilst running at idle( the battery will charge with an alternator)
    Worth pursuing this line of thought?
    Regards mark
    2002 defender 110 , 1955 86 inch
    Sep 2012
    Westlake ,brisbane
    It may be that the starter is drawing too much current.
    Aug 2008
    Any way of checking that( multimeter etc) .. the generator is relatively new so should be ok but I'll check it tomorrow...( dame fast awnser&#127867
    Sep 2012
    Westlake ,brisbane
    Auto Electrician should be able to do a load test with a tong tester.
    Sep 2006
    Warragul
    Battery
    Hi Mark
    I'm not far from you .
    Batteries have a theoretical internal resistance . If you look at it this way, the starter motor resistance , being in series or in line with the battery internal resistance . As you press the button the high current demand of the starter motor will cause a voltage drop across the battery resistance , the battery voltage will drop from 13 Volts down to as low as 8 Volts. If the battery internal resistance is higher than its normal working value ( a dud battery) , then precious Volts will be lost at the starter motor. This is why some cars have a ignition coil rated at 8 Volts , there is a resistor in series with the coil for normal driving, but when starting the resistor is bypassed and the coil gets the 8 Volts.
    Aug 2008
    Cheers. I'll have a look at how the battery's discharging under starting, I realy suspect it... I'll grab a decent battery and check it out if the multimeter during starting looks dodgey..... just kinda pointless trying to tune it with the starting issue interfering ... there's enough wear between the fuel system and ignition on this old girl to deal with an electrical supply issue
    ( yea close... met out at you're place with that flat hood stick exmoor trim god u patterned and shifted a windscreen loop on for me,must have been 3 years ago)
    Cheers mark
    Simplest way of checking whether the battery is the problem is to temporarily swap the battery for a known good one.
    But also check for bad connections. These can be found with a multimeter by checking the voltage between the battery live pole* and the starter, and between the battery earthed pole* and the body of the starter when the starter is operated. None of these should be over about 0.5v, if they are, check the path bit by bit to find the problem, usually at connections of some sort.
    * I have used these terms rather than + and - so it applies whether the original positive earth is still in place or the system has been changed to negative earth.
    When its cranking over you're not getting spark.
    when you stop cranking if its flooded as the engine speed drops off it wont fire.
    thats why it goes on the second crank sometimes. First time you dont have the fuel air mix to go, second time you do.
    if you have a meter with a max/min hold put it on the battery so its reading 12V hit the min hold setting and crank the engine. anything below 10v is bad and needs investigating.
    if the battery is over 10.5 start following the leads around the ignition side of the system and if you get less than 10v while cranking you need to fix that problem.
    Dont forget that you need to check with the meter earthed on the battery post to start with to rule out the battery and onto the block (or wherever your distributor points make earth to.
    best of luck. and dont forget the condensor if its fitted.
    Aug 2008
    Cheers jdnsw.. I've been working through all the connectors etc... trying to avoid pulling the battery out of the 110, but it will come down to it soon..
    Cheers blknight... the issue with needing the second press of the starter is likely because up until now I haven't had a functioning choke and I forget to use it first press.. pull it out 2 press it goes ( first start of the day ) also there's no feel to the supposed part out position .... but likley the spark is weak to as I need to sort this battery thing out first
    Cheers guys much appreciated
