Results 1 to 4 of 4
Thread: Help needed!
    Perth W.A.
    Help needed!
    Hi all.
    I am on P gasket duty and have discovered a chunk out the ali on the front plate to p gasket....anyone got a wrecked 300tdi kicking around in perth they would flog ...up against it got a transfer north shortly.
    Thanks in advance.
    Lardy.
    Dec 2008
    Lardy,
    A die grinder, Dremel or file down to bare metal with coarse finish and Devcon (available at Blackwoods and industrial suppliers) may be your friend for a temporary repair....
    And the best form of permanent repair is a really good temporary repair......
    I have used Devcon for many pump repairs with lots of joy!!
    Gumnut
    Ive used devcon, epoxy putty and expoxy resin to great effect before to day.
    Perth W.A.
    Thanks guys appreciate the input, was also wondering if a good ali welder could build it back up then grind it flush....Devcon seems a good one for now.
