Good to see they fixed the auto lowering of the suspension at 50km/h
There are two offroad suspension heights; +40mm for speeds of up to 80km/h, and +75mm for speeds below 50km/h, unlike the older model which auto-lowered to normal height above 50km/h unless you had one of various aftermarket mods to fix it. This addresses a problem I once used an entire feature article to complain about – many Aussie tracks require high clearance but you often travel above 50km/h. No more lowering of the car and then the compressor complaining about overheating as you jack it back it!
Keeping it simple is complicated.
