Results 1 to 10 of 11
Thread: Fuel bugs
    Eidsvold QLD
    Fuel bugs
    Have seen these magnetic diesel debuggers in a few mags, but at work we just use a fuel conditioner in our diesel for graders, loaders etc. Has anyone got any experiences with either treatment, thanks.
    Apr 2002
    Bellara 4507
    32.43 MB
    the magnetic ones are used extensively in marine work, they sit on the return line normally.
    they dont do much if you empty a tamk of jiuce a week, they are most effiecient on very large tanks with a fair amount of return volume.
    i use cem or fuel doctor in my disco.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    SYDNEY -in the shire.....
    <span style="color:green">i use fuel doctor (when i remember to put it in) but ive always got fresh
    fuel in the tank....
    i need to fill up weekly.....
    which doesnt give anything much of a chanceto grow in my tank...(i hope)</span>
    8)don't believe that it doesn't grow even when you have high consumption, most jet fuel aircraft require a treatment each fill.
    Safe Travels
    harry
    Apr 2002
    Bellara 4507
    32.43 MB
    are the onboard tanks infected or is it because it has been sitting for weeks in the storage tanks up the road?
    Golden Grove, Adelaide
    The jet fuel is dosed in storage usually, sometimes the the truck is dosed if the fuel is drawn from multi use tanks. Military/civie, but then they usually only need to spike FSII (for Military use) into the civvie fuel which would normally already have the anti clad mixed.
    Most retail diesel should have a certain amount of fuel conditioner in it when supplied to the service station. The fuel supplier at Weipa is obliged to inform my employer about the absence of fuel conditioner in the imported diesel he supplies. so I am guessing it is more the unusual than norm.
    Hills District, Sydney
    I had an L500 unit fitted to the GU 4.2 a few weeks ago.
    Ron Moon's fair dinkum,
    check this out:
    http://www.morison.com.au/4x4_3.htm
    XSI
    Toowoomba QLD.
    Thought I might fit one to the Fender. Fitted it into the low pressure line from the LP side of the pump which then goes back to the HP side of the pump then off to the engine. (Its the line with the blue collar on the filter).
    Also fitted the unit upside down as per the manufacturers suggestion to prevent water buildup.
    Fuel is in from the right hand side, out the left to the filter unit.
    Fuel line to be cut is the left hand rear hose on the filter. I cut it back about 80mm from the fitting so as to allow the reuse of the original fitting. A section of 8mm fuel line was then connected on to the original fitting, with the other end attached to the bug killer.
    We'll see how it goes over the next few months.
    Trev.
    South Yundreup,WA.
    Trev,
    What did it set you back? And who did you buy it through?
    Craig
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Nov 2005
    Maudsland, QLD
    I've seen a couple of guys run truck diesel filters on their 4x4's and these have a drain plug so you can release water and other crap out of the filter.
    also have seen them on a 4x4 monthly DVD - Tasmania Trip, I think
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
