Results 1 to 10 of 24
Thread: Camshaft Refit
    May 2015
    Victoria
    Camshaft Refit
    New cam fitted. Checking end float RAVE indicates .05mm - .35mm. Thrust plate has zero wear however my measurements indicate .65mm. More than RAVE suggests. I can't think of what I have done wrong. Checked new cam obviously RED. Does anyone have any ideas? Please help
    Avoca Beach
    I don't think it matters seeing all previous engines had no thrust plate and relied on the timing chain and the cam lobe slope to keep the cams in place.
    Some engines used to rattle at idle and a thrust button which rubbed on the timing cover was a factory fix .
    But in practical terms I would not be concerned.
    Regards Philip A
    May 2015
    Victoria
    Water pump gasket, RAVE says to strictly use Shell Retinax LX grease. Where can I find? Are there any alternatives?
    Feb 2010
    Townsville, QLD
    I've never used any form of sealant on a water pump gasket in the 7 years I've been P38ing. No leaks, no issues! As long as you've taken all the old gasket and sealant off and the face is smooth you won't have any dramas.
    Keithy
    Feb 2013
    Gosford, NSW, Australia
    Quote Originally Posted by Anthony Violi View Post
    I sometimes smear a little grease on the gasket to hold it in place while I get the bolts in, but it's just whatever I have in my grease gun !
    Steve
    May 2015
    Victoria
    ARP studs in, first torque 100 ft lbs done. Second torque, first stud top centre and stud pulls away, taking thread with it. My fear realised.
    Do not know what to do next, help please?
    Anthony
    Mar 2007
    Warwick Qld
    100 ft/lbs sounds like a lot for something screwing into aluminium. IIRC that's about what we used to do M12 bolts up to for clamping pump flanges together.
    I suppose helicoil or something similar is your next step,
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Feb 2013
    What a bummer mate
    I did mine in three stages, I seem to remember 33, 66 then 100 and I had no problems at all.
    A helicoil will do the job and give a very strong hold, but it's weird you stripped a stud like that.
    I assume you cleaned out the holes in the block and got the studs all the way in ?
    Good luck
    Steve
    May 2015
    Victoria
    Hand tightened using Allen key, checked all the heights, cleaned out holes, spotless. The only thing I can think of, perhaps Elgin gaskets too thick?
    Helicoils not sure, some have had successs others not. Metal inserts another option. Do these options require engine out?
    Feb 2013
    I can't see how the gaskets being too thick would cause a stud to strip.
    Others will have opinions on helicoils v inserts, and you should not have to take the engine out to do them.
    Maybe ask in the tech talk section of the forum ?
    Steve
