Results 1 to 4 of 4
Thread: Discovery 3 Dual Battery System
    Geotrecaz Guest
    Has anyone had a dual battery system installed in Disco 3?
    tombraider Guest
    Hello my fellow geocachers!
    Its easy enough to do, the battery goes just in front of the brake booster on the drivers side :wink:
    All you need is a way to tie it down and an isolator.. Use a traxide isolator and just measure the available space under that cover.
    Come for a run up to Whyalla and we'll sort it out over a beer/scotch/red wine or two 8)
    Mike
    (Team Raider)
    Queensland
    Nedlands, WA
    I had a Odyssey 1200 installed next to the brake booster and it works well. It has a TJM isolater and a heavy duty fridge connection running through to the rear.
    ARB has also rigged up a system in the same location.
