Results 1 to 10 of 26
Thread: tranmission overheat
    Williams West Aust
    Yesterday I got an orange triangle and transmission overheat.I was stuck in traffic,bloody xmas shoppers and shire workers closing 1 lane to water the median strip.
    It was VERY HOT in Perth yesterday,outside temp was showing 48degC,obviously heat from the road,it dropped to 42 once mobile.
    Fortunately I got a red light just as the warning came up,slipped it into neutral and held the revs up,it went out in about 30 seconds.
    Anybody else had overheats with the 8 speed in hot weather towing???? Wonder if its worth fitting an additional cooler inline???
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    mikeford Guest
    Interesting
    I have a 2012 D4 with the last of the 6 speed auto trans, couple of years ago I went and played at Loveday 4wd park, it was 48c and there was lots of low ratio driving, my air condioner stopped cooling for a while which is normal when the engine gets very hot. Did not get any transmission alarms though .
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Andrew
    thats what i would be doing.... fan assisted
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2015
    Coolamon, NSW
    Andrew
    Might be worth hooking up the IID Tool and having it display gearbox temp for you - I know I would be if towing in those sort of conditions
    - Justin
    Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
    Moved into MY12 L322 4.4 TDV8 Autobiography
    VK2HFJ
    Aug 2015
    I tried to get the transmission shop to fit one when they did the rebuild on mine Andy but they weren't interested.
    Although i wanted to isolate it from the radiator completely rather than fit inline like you're saying to prevent ever mixing coolant with trans fluid in the event of a crack or leak...
    When i looked into it, there was only a kit available for D3s i believe .
    I have done it before to the last zf 6 speed i had in the Ford... Just mounted it behind the front bumper, there should still be plenty of room for us to do the same thing.
    Bunbury, WA
    Andrew
    Sounds a bit disturbing Andrew .
    I've towed the boat and car trailer in hot weather and not had that issue (to date). I don't have a solution but will keep an eye out.....
    Oct 2012
    Quote Originally Posted by LandyAndy;
    Andrew
    I remember Gordon stating that the D3 (post 06) & D4 cooling system was extremely overspecced. As you weren't climbing mountains at the time this is surprising.
    Oct 2008
    Cloncurry NWQ
    Are the rads & coolers full of bugs, seeds or mud/dust?
    Perhaps Andy needs a Diet tranmission overheat
    Mar 2007
    Kalgoorlie WA
    Maybe it was the ironing board strapped across the front of the bull bar.
    Cheers .........
    BMKAL
