Results 1 to 10 of 21
Thread: Time to replace coils packs on Thor
    Sep 2012
    Perth Australia
    Hi Guys
    for those that have done this how much time should i allow to get this job (replacing coil packs) done.
    Cheers Paul
    Crafers West South Australia
    A couple of hours or less, if your wrists are flexible and your fingers are sensitive. Firstly undo the 6mm stud holding the heater pipe by undoing it with 2 nuts jammed together. Catch the spacer that's between the pipes and the plenum. Undo everything around the throttle body.
    The removal of the plenum top isn't that hard but first you need to undo and remove the two top bolts from the coil pack bracket. A 7mm 1/4" drive socket, 6" extension and ratchet will allow you to reach and remove these. Next move, which is a little more difficult, is to loosen the two lower coil pack bracket bolts by only 3 turns. Again with the 7mm socket but you need two extensions to reach them as they are low down. Once they are loosened the last bolt holding the plenum top can be undone. Don't forget the one low down on the front of the plenum centre line either. Once the plenum top is off you can remove the two 7mm headed bolts and do the coil pack swap.
    Reinstallation requires you to put these two lower bolts in but leave them loose enough so that the bracket can be swung forwards and backwards. Make absolutely sure the connector plugs are securely clicked onto the coil packs, as they will otherwise jump off. Once the plenum is reinstalled fit the two upper 7mm headed bolts and tighten all four.
    Good luck!
    Sep 2012
    Perth Australia
    Thanks bee utey
    That answers all my questions and then some
    Paul
    Oct 2007
    Williamstown, Victoria
    Hi Paul, what symptoms are you having to make you replace the coil packs?
    Cheers, Pete.
    Sep 2012
    Perth Australia
    Quote Originally Posted by PeterH View Post
    Cheers, Pete.
    Hi Peter,
    It is missing on more than one cylinder, only started recently. It's not my daily driver but heading on a trip with it soon.
    I'm tackling the coil packs first as I've had spares sitting around for a while and always planned to fit them.
    Also replaced plugs and leads a few thousand ks ago.
    Hopefully the coil packs fix it.
    Paul
    Feb 2010
    Townsville, QLD
    I did mine in September for the exact same reason. ***** of a job when LPG gear is attached everywhere on the manifold too, so I outsourced the job. Fixed my "cylinders missing" issue straight up!
    Keithy
    Sep 2012
    Perth Australia
    Keithy I hope it fixes mine the same.
    Just need a cooler day now to tackle it.
    Paul
    May 2003
    On The Road
    I was told dropping an engine mount first made things easier
    Also should be which a " plug leads to which coil pack" pic in here somewhere,,,, just in case ��
    Sep 2012
    Perth Australia
    I love shortcuts Pedro so I will definitely look into that.
    If engine mount removal was a 5 minute job I'd have suggested it. Pulling off the manifold top is far quicker. I reckon that I could do a coil pack swap in under an hour now that I've done a few, my way. It's even faster if you've already bypassed the throttle body heater.
