Results 1 to 10 of 28
Thread: TDV6 v SDV6 Off road
    Shane_O_16 Guest
    Hi All,
    I am looking at moving from a Prado to a RRS and have used the Prado off road and have had to use low range on some occasions in soft sand and even been close to being bogged hard. The TDV6 doesn't have low range and a less advanced 4WD system than the SDV6 and I am wondering if I will be satisfied with the TDV6 or if I should be considering the SDV6 instead for it's ability.
    I use the car mainly on beaches and sometimes the sand has been quite soft.
    Any advice would be great as I would hate to spend a heap on a car and for it not to do what I need.
    Shane
    Brisbane,some of the time.
    If you go no low range you are only guessing how you will go.
    If you take the other option,i know it is a few more $$,but you will have nothing to worry about.Resale may be better,so in fact in the long run,nothing to loose.
    For me i would not consider the model with no low range.
    Low range has pulled me out of trouble numerous times,and not only in soft sand....
    Oct 2003
    Montrose, Vic.
    I'd tend to lean towards the model with low range, but that said, it probably depends a lot what you class as "Off road"
    We all have our own view as to what conditions would be considered "easy" , "medium" or "hard" off road... and where you sit, should probably influence your decision significantly.
    Range Rovers without Low range are a relatively new product... so you aren't likely to get a lot of opinions from those that have owned or driven them.
    However Land Rover have had vehicles without low range for quite some time ( Freelander and Discovery Sport)... I have seen Freelanders taken quite successfully off road in places most would say you need low range. They definitely did it harder than the Discoverys, Defenders and Rangies... but they are certainly not on road only vehicles.
    If you intend to drive very steep hills, cross rivers, deep mud or very soft sand, low range is a big advantage....if you want to tow a caravan across outback gravel roads..... I'd save your cash and go with the TDV6
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    If you tow. I'd go the SDV6 and make sure you have low range..
    Low range is absolutely brilliant for reversing a van/trailer etc with control and precision..
    Jun 2008
    McMinns Lagoon NT
    I didn't realise that feature came complimentary with low range.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Quote Originally Posted by Narangga View Post
    Using low range when reversing a big item gives so much more control and much less stress on the vehicle..
    I use it regularly...
    Especially useful when reversing a heavy trailer up a steep driveway.. much less stress on the transmission and much more control. TDV6 v SDV6 Off road
    DiscoMick Guest
    Eight speed autos can be quite impressive off road and in sand.
    That said, I'd still prefer to have the option of low range.
    Sent from my A1601 using AULRO mobile app
    Quote Originally Posted by DiscoMick View Post
    Yes. But they have yet to solve the single reverse..
    I'm sure it's coming.
    Shane_O_16 Guest
    Thanks for the replies so far and it seems there is little information on how these go off road. Maybe people don't buy these and take them off road a lot...who knows.
    For me off road is classed as medium, but dictated by the fact that I have had to use low range and always reduce pressures to 16-18psi, lower on a couple of instances.
    Pros
    Torque - the amount of torque and less weight would mean it would sit in bewteen Prado low range and normal gearing for multiplication
    ATS - more advanced 4wd system would compensate a little
    Suspension - more articulation, travel and height
    Cons
    No low range
    Wheel and tyre size - regardless of spec it doesn't give you much options for good off roading tyres sizes
    The SDV6 is obviously ideal but why spend the extra if I don't need to is the question I'm trying to answer.
    Cheaper to buy. Cheaper to Sell.
    And offroad if it's rougher than a gravel road the non-low vehicle will do it a lot rougher, faster and more violently.. (you'll have to hit things harder)..
