Results 1 to 3 of 3
Thread: cheap mini oxy set
    Feb 2013
    Ballarat,Vic,Aus
    cheap mini oxy set
    oxy set for $130 at total tools...
    Bernzomatic - Mapp/Oxy Soldering Torch Kit - OX2550TK | Total Tools
    this would have to be perfect for freeing frozen stuff ... It's only a dinky toy ... but check this out
    [ame]https://youtu.be/kt7Gb2S-z4Q[/ame]
    i'm sure the disposable bottles aren't cheap .... but ... $130 bucks
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Aug 2008
    Perth, WA
    37.36 MB
    I saw a similar kit, but a bit more expensive, at Autobarn. The replaceable cylinders were at least $30 ea from memory, probably much more. I figured if you were stuck somewhere it would be a handy thing to have, but you are right, the cylinders aren't too big. If you took it on a trip, bring some spare bottles and it would be a great little unit.
    Jul 2011
    Yarrawonga, Vic
    I bought one from SCA on special, good for silver soldering brazing small parts, thats about it. (jewellery / Model making) Not a patch of a proper oxy set . A full o2 bottle weighs the same as an empty one .
    Forget about cutting anything, empty the o2 bottle in about 30 seconds flat .
    get a Plasma cutter.
    It wont work with LP Gas as the fuel, has to be MAP.
    For trying to loosen rusted / stuck parts or bolts get some Loctite Freeze & Release . Works better than a combination heat / cooling/ WD40
