Results 1 to 10 of 13
Thread: Iveco Daily 4x4 Motorhome
    Mildura,NW VIC
    I am considering purchasing a motor home based on a former SA Country Fire Service vehicle.I feel it would be very outback travel capable how ever the only fault I can see is the very low highway cruising speed of 85kmh.
    It is a 1995 model49.12 3.60M code1313132
    I also have the vin no but wont publish on open forum.
    I would like to know if an overdrive could be fitted for hghway cruising or would diff ratios need to be changed.RA ratio on compliance plate says 4.4
    Also would this be a prohibitive cost to undertake
    Eagerly awaiting some help with this dilemma
    Mary
    "Some people walk in the rain,others just get wet!" -Roger Miller
    in the wild New England, NSW
    Wow ! - sounds like a formidable vehicle Mary - you would be able to carry heaps of stiffen your travels.
    Fuel economy may be a bit disappointing. I do not know what gearing alternatives are available. Hopefully one of the Iveco users will chime in.
    Further investigations, research & trial drives will help you decide I hope.
    Would you ever need to change a tyre? (I think they're very heavy) and you'll need a high clearance carport/garage
    All the best with whatever decision you make
    Mildura,NW VIC
    iveco 4x4
    Thanks for your reply
    Changing wheels is the least of my concerns atm.I can change a Defender wheel in most circumstances at my own slow and steady pace using maxtrak to roll the wheel down off the door and back up again
    With the Iveco I am really seeking knowledge of any known faults of the 1995 models
    Ie anyone who had experience of these vehicles when in service with SA Country Fire Service would know of any inherent mechanical problems
    Also would anyone know if parts for these are available or would I be purchasing an orphan
    Only other 2nd hand 4x4 small motorhome I can find is based on a 4x4 Hilux .Not as capable but easy to source parts mech expertise in outback.
    Hoping someone with Iveco experience can help
    Mary
    May 2008
    Bundaberg Qld
    I think the Lux would be on it's limit with a motorhome body on it
    Jul 2011
    Yarrawonga, Vic
    There are less than a handful of 49.12 4x4 Ivecos in the country. I believe this is a 2nd generation Iveco.
    Parts will be a problem for sure, you will be on your own there.
    There is no reason you should not be able to do over 100kmh with 4.4 diffs considering the Overdrive 5th gear and 1:1 High Range, there is no external override availability . what size tyres has it got ?
    Reliable vehicle, Italian Electrics on par with Lucas, No Computers.
    suggest you trawl the Iveco Forums Iveco Daily Forums
    Mildura,NW VIC
    Tyre size 7.50 x16
    Thanks for your advice.Havent driven it but dealer says 85kmh top speed
    Don't want to buy something that will be difficult to source parts or mech expertise to fix probs
    Should have bpught a 6x6 Perentie and built a motor home on it
    Mary
    Quote Originally Posted by malleefowl View Post
    Mary
    6X6 Perenties are even slower , and probably a bit noisier
    Apr 2013
    Bemboka NSW
    Mary, buy an Oka. It is the ONLY vehicle that will satisfy after a Land Rover!
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by Silenceisgolden View Post
    No the New Iveco 4x4 satisfies a LandRover owner ,
    They are Individually Hand Made to order
    They Leak Oil
    The Transfer Case runs Hot
    They have Electrical Issues
    Hoses rub through
    Every one is unique & each drives very different & they definitely have their own personality
    The dealers suck & no one else will work on them
    Never say yours is going great unless touching a piece of wood
    They are a extremely sure footed & an awesomely capable 4x4 !
    That list will satisfy any LandRover owner but .....sorry they dont leak water or dust .
    Apr 2013
    Bemboka NSW
    They Leak Oil
    Hoses rub through
    Yes, but....... The Iveco doesn't satisfy the "Meccano" experience, so beloved of Oka and Land Rover owners! The Iveco is more Lego-meets-ipad.
