Thread: Land Rover Defender '97 300tdi diesel leak
    Oct 2016
    Hello everyone,
    I've got an unfortunate diesel leak, took a picture of it where it's leaking. Is it alright to do like a 20km drive with it?
    Kyra.
    St Helena,Melbourne
    4.28 MB
    Silly question but have you tried tightening it ?, need 2 spanners so you can hold one end and do up the other.
    If its just a drip you will be ok, but you could take that injector pipe off and check the end to see why its leaking and maybe clean it up.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2008
    Geelong
    The lift pump is also a likely cause given all the wetness around and underneath it. Go ahead and drive it but get it fixed soon.
    Aug 2012
    Logan,Queensland
    I agree with give it a tighten.
    probably could degrease the area as well to help track down the source.
    If the rigid line is damaged I do have spares here if needed.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Oct 2016
    I tried a bit here and there but all of the sudden there was also an oil leak (which was not due to diesel leak) so went to the mechanic. Apparently the whole pump needs to be replaced and since the car is 20 years old that's not a shocker. The price is..
