Results 1 to 10 of 18
Thread: Wingmirror glass replacement
    Melbourne, mostly
    I've got a convex glass replacement for my wingmirror. However, I can't see an easy way to remove the glass. Nothing to undo. Only option seems to be to use a flathead screwdriver and gently lever. Any ideas?
    tia
    8) i have v8 '95 disco and to get the left mirror glass out all i had to do was sideswipe a railing in the carpark as i dodged a speed hump.
    the actual glass and the plastic thing it is fitted into just pop off, although it is broken i still managed to pop it back in place by hooking the inner end in and useing a screwdriver to click the outer end in.
    damm speed humps!
    damm railings for elderly cits!
    now where did you get the new glass from?
    Safe Travels
    harry
    Toowoomba QLD.
    Re: Wingmirror glass replacement
    tia
    Disco or defender?
    Trev.
    St Helena,Melbourne
    4.28 MB
    Wing mirror? ozzie cars only have mudguards and the mirrors are on the doors ?
    tombraider Guest
    Defender glass is just stuck on
    Levering is the only way Wear Safety Glasses and gloves :!: 8O
    If you got the glass from OS check its the same size, I did the same but UK and US mirrors are smaller.
    If it is correct size, where did you get it :?:
    Mike
    Toowoomba QLD.
    I also did the same. I purchased the new smaller Defender mirrors from LR Brisbane. Bonus is the curved mirrors are better, more stable at speed, and better vision. I did both sides.
    Trev.
    tombraider Guest
    Got the part numbers handy somewhere????
    Mike
    Toowoomba QLD.
    Mike
    Just been looking. I can't see it anywhere. The mirrors are NAS "left hand only". Just buy two. They go on the existing mirror arms.
    Austral LR in Brisbane got one out of stock and the other bought in. Approx $120 each from memory. The arms are centrally mounted in the mirror case, and the mirrors are aerodynamically shaped, not slabs like the originals.
    Trev.
    Toowoomba QLD.
    Got it.
    MTC5084 Mirror Head.
    Trev.
    tombraider Guest
    Your a legend!!! Off to LR I go!
