I use a normal ring compressor. There is a counterbore above the cylinder bore which the compressor will slip into.
Could be a problem if the engine has been bored to the max, don't know what to do then. Maybe a strip of shim steel?
Terry
Hi
Anyone know how you fit pistons to a 6 cylinder land rover motor. The IOE block has a sloping top so you cannot use a normal ring compressor. The honed section does not come to the top of the bore. It looks similar to a series one block, so maybe has the same solution.
Steve
Terry
Not yet, but I'm about to rebuild one. I was thinking about this when I pulled them out. Does the manual say anything about it? I'll go check.
Oh, and welcome to the forum.. What's the engine going in? Any pics?
Well, the manual is no help - see the pic below 'using a suitable piston ring clamp'
Terry's advice sounds the most helpful.![]()
Back in the days when I couldn't afford fancy things like ring compressors, we used to use three or four strips of tin cut from a beer can.![]()
1999 Disco TD5 ("Bluey")
1996 Disco 300 TDi ("Slo-Mo")
I just used a standard ring compressor which I borrowed from the mechanic next door when I did it and from memory they just pushed in but be careful as I did break a ring on the first one I did when I used too much force.
I had it bored out to 40 thousand to get it back round again and I didn't have too much of a problem after the first one.
Richard
_____________________
1985 V8 County 110
1994 TDI Discovery 1
2000 TD5 Discovery 2
2010 TDCI Defender 110
Land Rover Owners Club of Brisbane
If you have the crank out you could put them in from the bottom.
K
Thanks for the replies. Had a bit more of a look at it tonight and the sloping edge leading into the bore is enough to allow the piston to slide in. Just needed a few taps with my hand to get it in. Engine has been bored to + 020 and using new pistons from JP Pistons in Adelaide. There is not enoug space for the ring compressor to fit into the top of the bore, there is maybe a 020 to 030 gap there, so using some shim steel or a cut up aluminium can may work. I'll give that a go after I gap the rest of the rings. Engine is going back into 1972 2a Flat tray. i also have a 74 series 3 flat tray with a Holden motor that is being used as a parts donor, mainly for the chassis. Not sure who thougt using wood to support a flat tray on the series 2a's was a good idea to prevent corrosion!
Steve
On my 80" I put them in from the bottom & on my Rover P3 75 I used a ring compressor to put them in through the top. I will admit I did brake the rings on one cylinder on the P3 due to not being careful.![]()
I usually just walk them down with my thumbnail and a small screwdriver, use the thumbnail to compress the ring into the piston and then push it downwards below the lip with the screwdriver.
the oil scraper ring setup can be a bit fiddly....
