10th January 2017, 03:36 PM
130 spring location cones
Just a heads up to anyone going down this path, if your 130 has the rear inner helper coil, relocation cones do not fit.
I just purchased a set of Terrafirma poly cone TF531XT advertised as fitting 110/130, but once I opened the box I knew there was a problem.
I was under the impression that all 130's had the extra spring, however after a phone call to the vendor, this is apparently not the case, and more disappointing it seems that there is no locator made for this set up at all.
I have Terrafirma shocks fitted which are obviously a bit longer than they should be, rarely do I get home without a spring unseated, anyone know if Bilsteins are the correct length??
Rich.
10th January 2017, 05:49 PM
If you order the correct ones they will be
10th January 2017, 06:21 PM
Retain the spring is an option
