<div class='quotetop'>QUOTE</div><div class='quotemain'>need a new diff again![]()
[/b][/quote]
please do tell 8O
What year did the rear and frond diffs change form the 10 to 21 spline
on the range rovers and from the 2 to 4 pinion gears :?:
[/b][/quote]
please do tell 8O
130's rule
any good pics on the fun you had breaking it!!!
2023 Defender 130 D300
SOLD - 2010 Discovery 4 V8
SOLD - 2008 Range Rover Vogue L322 TDV8
SOLD - 2006 Range Rover Sport L320 TDV6
SOLD - 2002 Range Rover L322 TD6
SOLD - 2002 Discovery 2 TD5
SOLD - 1997 Range Rover 4.6 HSE
SOLD - 1999 Range Rover 4.0 SE
Kai,
What have you done :?:
four pinion diffs only came out on the hse 4.6 and it was the rear only im not shaw when the spline changed
8O All that meat and no potatoes
I think only the Defenders had 4 pinion differentials front and rear.
Correct me if i am wrong.
I did say that the HSE 4.6 REAR diff is a 4 pinion carrier and im shaw the question was about rangies not defenders![]()
As far as I know they changed it when LR worked out there traction con trol. Which was 1993.
Originally posted by hiline
please do tell 8O
Not much to tell just gave up as it did last time stoped the car and had a look at a nice hard track but decided that you need a winch to get out at the end.
turned the car around and realised only front wheel drive we had a bit of fun getting back to the main road but with the help of a snatch en strap it all worked out well .
Then the noise started from the diff so i stooped and puled the diff out and removed the broken bits put it all back to gather and drove home on Saturday late afternoon.
now i need a stronger diff.
