Salisbury Diff Housing Internal Rust
I've just had my first play with using molasses for rust removal. Slow but very effective. You'd either need a container big enough to put it in or if it's only the inside you're concerned with just blank up the axle ends and breather, fit the cover then lay it down and fill it via the pinion hole. Leave it a couple of weeks then drain and hit with the pressure washer.
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
