Gorilla do black and silver ones that look to be one piece
Gorilla Automotive Products
 Master
						Supporter
						Master
						SupporterHi
Does anyone know a good place to get black wheel nuts (without caps) to fit a 2011 D4?
They mustn't have 'caps' like the standard ones as I switch wheels to go off-road and the one thing that makes this process painful is when I get a lug stuck in the rattle gun and have to spend time getting it out (tends to happen on 2-3 lugs each time I change over but Im confident this wouldn't happen with solid steel nuts instead.
I can see some on eBay but I have no idea what size/spec they need to be?
Thanks, Luke
 Master
						Subscriber
						Master
						SubscriberGorilla do black and silver ones that look to be one piece
- Justin
Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
Moved into MY12 L322 4.4 TDV8 Autobiography
VK2HFJ
Luke are you using a 6 point?
 Master
						Supporter
						Master
						SupporterHi Tombie, yep
 Master
						Supporter
						Master
						Supporter14x1.5mm is the thread diameter and pitch.
Not sure which shape you will need to get the right number of turns onto the stud though.
 Master
						Subscriber
						Master
						Subscriber- Justin
VK2HFJ
Luke is, I bought a set last year, definitely steel. Test to put them on as I am waiting for Compmotive wheels.
I am not at home now, will look up source when I get back to Sydney sometime
Mike
 Master
						Supporter
						Master
						SupporterThanks Mike, I appreciate that. Do you remember what you paid?
The gorilla website doesn't sell online (or direct) so I've emailed them to see if there are stockist in Aus, the Range Rover ones do look identical. No
Prices listed either
