Results 1 to 4 of 4
Thread: winch and winch bar
    Sith Guest
    winch and winch bar
    Greetings all , just wondering on the ARB Winch bar , can you bolt dtraight u[p a WARN 8274 himount , if not how much cutting is required and is there enuough room between the winch and the grill ??
    thanks
    Sith
    S.W. Sydney
    Hi
    There is a fair bit of cuting in the bar to fit the high mount but once done theres plenty of room between winch & grill and depending on the style of bar you may have to move the center horezental bar up an out as well
    Tony
    Sith Guest
    Thanks Tony , just hada look at the AMV blue Range Rover and it looks a treat !
    tombraider Guest
    I had a HiMount on my Defender with ARB bar.
    Just get some hi-strength alloy and make a spacer for the front of each mount point eg... 1 long block on each side.
    Fit longer bolts and it bolts straight up... Easy
    Mike
