Results 1 to 10 of 14
Thread: Air Filter Box Repair
    Mar 2015
    Engadine
    Following installation of a Safari snorkle recently I discovered that a number of the threaded holes on my air filter box that hold and seal the lid down are stripped. I guess for normal operation this has not been an issue (my mechanic has never mentioned it) however I wouldn't think this would be ideal when considering all the efforts Safari have made to make the rest of the airpath watertight. I'm wondering what would be the best filler material to use to fill the holes so I can re-drill and cut new threads with the existing screws? Has anyone out there done a similar repair?
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    Jun 2010
    Central Coast NSW
    Plastiweld or something similar might work.
    Jan 2015
    Assuming the box is made of ABS (and I'm sure someone will pipe up and tell us if it's not), I have had success in the past repairing ABS by making up a paste of it to use for repairs. (I was fixing the lid of a roof pod that had a very complicated crack on the corner)
    If you use a priming fluid based on Methyl Ethyl Ketone (MEK) like this: https://www.bunnings.com.au/protek-2...fluid_p4750123 you can 'melt' (/soften) small ABS pieces - I did it in a glass jar - to a gel / paste that you can then push into the repair. It's very easy to work with and once the solvent evaporates it's very solid.
    I think you can buy ABS pellets but that's a bit of a nuisance. I searched around the house and found part of a (no longer used! ) toy that was ABS and cut that into little pieces to make my repair paste. You can tell really easily if the material will work by putting some of the solvent on it - it will wipe off the surface of it.
    IIRC Acetone will work as a solvent too but MEK is better
    HTH
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Perhaps just a thread size increase on the screws?
    Factory size screws is hardly worth the effort..
    Dec 2011
    Forrestfield WA
    My mechanic has gradually put in larger screws over the years as they strip but there are still one or two that are not good. The screwed lids that LR now use (the same thing on new DS) is a pain and I hate it when you want to check your air filter on dusty roads. I tend to open it as little as possible and leave it dusty.
    The housing on my son's D1 is way better and user friendly.
    Bob
    Mar 2015
    Engadine
    Quote Originally Posted by l00kin4 View Post
    Assuming the box is made of ABS (and I'm sure someone will pipe up and tell us if it's not) ...
    David
    Searching the interweb I've found that ABS has a density of 1.06 so will sink in water whereas polypropylene has a density of 0.946 so will float. I'll try a density test with the lid (assuming it's the same material) and see what I find.
    Oztourer
    They only strip from heavy handed tightening - slap your ham fisted mechanics Air Filter Box Repair
    Dec 2011
    Forrestfield WA
    Yeah, very true.
    It is probably because they use electric screw drivers on them from what I have heard. I am not too happy about it all to be sure but what is done is done and there is no proof of who did what!
    It may have even started when ARB installed the Safari snorkel because it wasn't long after that, when I went to check my filter on a trip, that I noticed some screws were stripped.
    Bob
    Williams West Aust
    Not only are the screwdrivers electric they hammer too.
    Every CAT mechanic that comes to service our pair of 12M's use them to take panels off,even seen them use them to undo the torx screws on the dash assembly.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Brisbane,some of the time.
    Quote Originally Posted by BobD View Post
    And then they went to the D2 air filter box which leaked like a sieve around the seal
    At least the D3/4 air filter box is a massive improvement on the D2 setup
    I would do what tombie suggests,next gauge screws.
